Re: Farmall Cub snow blade fitting/converting to a Farmall A
Posted by gocartbuilder on August 21, 2009 at 10:27:53 from (71.13.81.153):
In Reply to: Re: Farmall Cub snow blade fitting/converting to a Farmall A posted by mkirsch on August 21, 2009 at 05:02:11:
At the time of my post I did not know of the earlier posts. However after searching back several years and studying several posts, I think I know what I am going to do. I also can purchase a 6 ft fairly heavy duty blade for $75 with out any brackets. I am going to fabricate brackets to attached to the rear hitch housing and either the bely mount or the front mount behind the steering box for the lift pivot point. The lift should not be a problem. I plan on adding spring tension to the blade for shock absorbing. Thanks to all who responded. I will post photos when I have it done.
