Re: Super H Oil Pressure Problem
Posted by Allan In NE on August 21, 2009 at 09:48:18 from (148.78.100.118):
In Reply to: Super H Oil Pressure Problem posted by Mark Peters on August 21, 2009 at 09:32:38:
Dunno,
Both my H and M run all day long at 60psi. The diesels all run at 75.
Allan
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
