Super H Oil Pressure Problem
Posted by Mark Peters on August 21, 2009 at 09:32:38 from (66.222.4.245):
Hi fella`s, I have a problem on a late `53 Super H that I use very,very little. I dug it out of the shed the other day because I want to use it at a plow day this fall to put a few hours on it.My problem is after it started, the oil gauge went all the way to the right and stays there even after the engine warms up.It never used to go that far to the right before,so I`m wondering what the heck happened. I tried putting a different gauge in thinking the old one may have went bad, but the new gauge shows it running at 60 lbs pressure,which is way more than it did and should be at. I`m at a loss at what happened . Would an oil passage have plugged up from sitting ? I`m open to any ideas. Thanks,Mark
