Posted by tractornutjd on August 21, 2009 at 09:53:18 from (208.105.228.179):
Hi, how valuable or collectable is a 39 Farmall M. It has the orignal seat although rusted in the frame work pretty goo. Hasn't run in 5 years. nose is good, hood a little banged up, good rims bad tires, has hyd pump that he never used in the 20 plus years he's had it. no hyd hose, ports plugged. which ones would I tap into? I want to pull 3-14 jd555 plows. Are these M's hard on fuel? Thanks Pat
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
