Re: Super H Oil Pressure Problem
Posted by NDS on August 21, 2009 at 14:48:11 from (64.12.116.73):
In Reply to: Super H Oil Pressure Problem posted by Mark Peters on August 21, 2009 at 09:32:38:
There is a relief valve in pump that should relieve pressure at 60 to 70 psi, the valve may not have been seating before. A good tight engine will run up to relief valve setting.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
