Re: Super H Oil Pressure Problem
Posted by Janicholson on August 21, 2009 at 15:34:05 from (64.61.211.53):
In Reply to: Super H Oil Pressure Problem posted by Mark Peters on August 21, 2009 at 09:32:38:
Run it, the oil pressure relief was stuck part way open with a piece of crud. Change the oil if you want to. 15-40 would be my choice. It is fine. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
