Offset Farmall question
Posted by Hugh MacKay on August 22, 2009 at 17:16:48 from (209.226.247.83):
I assume some of you know this, I've just never had a reason to investigate. On top of rearend housing two 5/8" threaded bosses used in the past for hand lift levers as well a Super A levers for split rockshaft for two way plow. My tractors have all had cork in those holes since new. Last week I chose to use those two holes to mount a shade umbrella on my 140. The cork was in bad shape, could definitely leak. I didn't take time to check this on 140, just used 5/8"x1-1/2" bolts with lots of gasket black around plate for umbrella.
My question, are those holes open to the rear end on bottom, or do they have a cast in place bottom? If they are leaking water into rearend, I'm thinking I should dig the cork out on SA and 130, replace it with a 5/8"x1" bolt with ample supply of gasket black.
I know some of the drawbar mount holes on final drives have cast in place bottoms, and if one uses too long bolt he can break out that thin cast bottom.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
