Re: After further checking....
Posted by Chuck's Repair on August 22, 2009 at 19:37:46 from (162.40.106.144):
In Reply to: After further checking.... posted by Dan Swanson on August 21, 2009 at 07:41:25:
If the problem is only on the one outlet and not the other then check to see if the unlatching mechanism is starting to unscrew from the valve spool. That would change the location of neutral position of the spool and keep the system on high pressure.
Chuck
