After further checking....
Posted by Dan Swanson on August 21, 2009 at 07:41:25 from (63.172.255.241):
In Reply to: 806 hydraulics under load.... posted by Dan Swanson on August 19, 2009 at 18:57:14:
I switched to the other set of couplers and all works fine, so I'm taking Chuck's lead and check the bypass valve. Thanks for the help. Let you know what I find. Dan
