Re: Cause of intermittent knock in 45 M after it has run ...
Posted by Dick Binfield on August 23, 2009 at 21:29:08 from (207.91.20.182):
In Reply to: Re: Cause of intermittent knock in 45 M after it has run ... posted by Janicholson on August 20, 2009 at 09:16:57:
Furher investigating indicates the noise comes from the main shaft in the transmission housing. One can feel the abnormality through the top plate of the gear case at the same time the noise is heard. What is the best remedy? 85 -140 gear lube instead of 80-90 or maybe some Lucas additive to see if it helps. Also oil pressure after 20 min of running drops from the 60 peg to straight up or a little to the left of straight up. Comments on either problem
