Re: Cause of intermittent knock in 45 M after it has run ...
Posted by Janicholson on August 20, 2009 at 09:16:57 from (199.17.6.186):
In Reply to: Cause of intermittent knock in 45 M after it has run a while posted by Dick Binfield on August 19, 2009 at 19:19:44:
A knocking sound when an engine misses is not uncommon. Especially if the misfire is a preignition when well warmed up. Several things can cause it. High heat range plugs, Worn plugs, Carbon deposits, Poor gasoline grade (regular unleaded pump gas is just fine), Irratic timing from a cenrtifugal advance mechanism going to the "weeds", or from point bounce from a bad spring, or from a loose bushing in the distributor shaft causing irratic dwell (No feelable play should be in the shaft. Less than .001" radial movement. A stickey valve will also make the same noise. Good luck with this laundry list. JimN
