Re: h or m governor
Posted by D Slater on August 24, 2009 at 13:53:37 from (72.65.136.11):
In Reply to: h or m governor posted by farmall66 on August 24, 2009 at 09:27:09:
Main housing and parts inside are the same, drive gear, top housing, vertical linkage rod, throttle tube and shaft to carburetor are all different. Since everything except the top housing and drive gear is special non stock parts with the M&W the answer is no and use all the M&W governor from a H on a M.
