Re: Adjusting '64 806 TA....
Posted by MN Scott on August 24, 2009 at 18:33:20 from (12.157.197.244):
In Reply to: Adjusting '64 806 TA.... posted by Dan Swanson on August 24, 2009 at 12:21:21:
The top valve is the TA control valve. Its connected to your TA lever on the side of the tractor. That little valve in back with the little rod and spring actuating it is the dump valve that releases the TA every time the clutch is depressed.
