Posted by neblinc on August 26, 2009 at 08:29:12 from (76.79.50.58):
In Reply to: H help with shifter! posted by wilkens on August 26, 2009 at 08:14:39:
Most likely your shifter lever is worn, not that hard of a fix.
There is a pin that holds the lever to the casting that needs to be removed. Some will have metal caps to keep the pin in place, some can be pried off, otherwise just drive a punch into one side and the other side will pop off.
Your shifter should look like the pic below, if not, it will need to be built up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
