Randy, I got the 3 shift rails lined up OK but I see something that doesn't look right. Do you have the specs on the large and small swivel shaft pin diameters? I've a hunch someone long ago rebuilt these pins--not to spec, or IH was sloppy. The large 3/4" pin has a 1/2" dia.(plus or minus 1/16") hole through it for the small pin which is WAY off center. Also, the small pin is WAY smaller (3/8" dia.) than the hole in the large pin. Seems awfully sloppy--unless it is designed that way. The shifter lever is close to the specs in your photo. The .75" width is worn just slightly narrower. Sorry for the length of this message but had to get it right! Thanks again. Emails welcome too.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
