Re: Offset Farmall Rockshaft Arm
Posted by Janicholson on August 26, 2009 at 19:25:52 from (64.61.211.248):
In Reply to: Offset Farmall Rockshaft Arm posted by Hugh MacKay on August 26, 2009 at 17:34:26:
Teddy is on to it. I believe in putting the strain on the bolt shank if possible, making a collar that will slip behind it is better than risking the case, or bending something inside. Then a solid blow to the side of the arm at the taper, 90 degrees to the axis of the shaft. Jim
