Offset Farmall Rockshaft Arm
Posted by Hugh MacKay on August 26, 2009 at 17:34:26 from (209.226.106.38):
Have any of you ever had trouble getting outside left rockshaft arm off the shaft. Shaft is tapered where the arm fits, looks to be held by nothing more than the big nut. It should pop right off, am I missing something? I'm using a forked bar. My puller wont hook behind the arm. Tried a big cole chisel, not thick enough and hits shaft before applying pressure on arm.
I've never had a left one off before. I've had a couple of right rockshaft arms off over the years, usually couple of cracks with hammer and they pop right off. This is my 140 and I need to remove the inside arm that operates hitch.
