Re: Offset Farmall Rockshaft Arm
Posted by Janicholson on August 28, 2009 at 07:01:58 from (199.17.6.222):
In Reply to: Re: Offset Farmall Rockshaft Arm posted by Hugh MacKay on August 27, 2009 at 18:08:43:
I think they are cast nodular iron or steel. Thus serious whacking is OK. a cutting torch (with no use of the oxygen lever) used to flash heat the arm at the taper (and avoid the shaft can be OK as well. JimN
