Re: Offset Farmall Rockshaft Arm
Posted by Hugh MacKay on August 28, 2009 at 14:05:41 from (209.226.247.100):
In Reply to: Re: Offset Farmall Rockshaft Arm posted by Janicholson on August 28, 2009 at 07:01:58:
Jim: Thanks, I'll adhere to that little bit of advice. I haven't got back to it since. I did leave the nut off a couple turns. I'm not working the tractor other than moving some items around the yard.
