Re: New wire harness... or wait?
Posted by ScottyHOMEy on August 28, 2009 at 12:21:00 from (71.241.214.74):
In Reply to: New wire harness... or wait? posted by Mike CA on August 28, 2009 at 12:06:24:
If you're getting a VR, you can use a three-position switch. The lower two on the 4-position were to regulate the charge manually. On the 3-position, it's strictly and off-dim-bright for the lights, since the VR is regulating the charge.
Light guts can be done anytime.
It's a toss-up between the mag or the wiring. Your tractor runs, so you can buy the wiring for the mag set-up and use some of the old wires for a while to keep your distributor going. Or you can do the mag first and eliminate some wiring, and gt the harness later.
