47 Farmall H, gear oil leaking after gear oil change
Posted by wfd2 on August 30, 2009 at 18:09:18 from (68.245.210.170):
Ok, amnion was right on his last post about what gear oil to use! I now have a leak...
I drained and added the correct amount of gear oil in the Farmall H. Maryland has quite a few rolling hills, and when I parked it today, the nose was pointed down a slight decline.
I noticed after about an hour, gear oil was dripping out of the inspection plate right after the hydraulic pump and before the rear.
Any ideas on how to fix this "easily"? Does anyone have an idea which seal could be leaking?
Thank you in advance!
Bill
