Wfd2, welcome to the world of H's. That is a very common thing to happen. The seal on the driveshaft is bad, most H's are and most ran a little low on gear oil so it was never noticed. I have two H's and both leaked after draining and replacing gear oil with the proper amount. You remove the cover on the belly and the belly pump if you have one, then undo the driveshaft and you have access to the seal, turn the collar off and pick out the seal and replace..not a hard job, a little harder if you have a belly pump to remove. What you described is quite common to find in an H or an M.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
