706 diesel injection pump
Posted by andy r on August 30, 2009 at 20:16:48 from (69.66.71.73):
The 706 diesel is a recent aquisition. Good power and starts right up. No smoke. I really don't want to take the injection pump off. The problem is the injection pump seems to be doing some slight dripping from one or two little covers on the side. The upper one looks like a washer with a bolt coming through the center and the bottom one looks like a washer the shape of a hex nut with a bolt coming through the center. These are on the outside of the injection pump, not towards the block. If I pull them off will I find rubber seals that need replacing??? Thank you.
