Re: 706 diesel injection pump
Posted by jdemaris on August 31, 2009 at 06:13:39 from (67.142.130.46):
In Reply to: 706 diesel injection pump posted by andy r on August 30, 2009 at 20:16:48:
If a Stanadyne/Roosamaster, all those seals are either rubber o-rings, steel washers, copper washers, and one aluminum washer.
You can buy the entire seal kit for $14.
Some you can easily replace from the outide without disturbing anything, and some are not so easy.
Here's a generic photo of a Roosamaster/Stanadyne pump. Can you point out what parts are leaking?
I assume you've got the DBGFC 631 20AJ or 40AJ pump?
If not a Stanadyne, then disregard.
third party image
