Re: Woodruff key repair in P.S. shaft
Posted by James A. Nicholson on August 31, 2009 at 08:14:05 from (199.17.6.222):
In Reply to: Woodruff key repair in P.S. shaft posted by SDE on August 31, 2009 at 03:28:47:
Best of all possible is to have the shaft recut at a machine shop to enlarge the key. then broach the hub to match. Enlarging with dremel tool and patience is OK if very careful attantion is given to fit and accuracy. A jig could be made to hold a Woodruff cutter in place on the tractor.
Another alternative is to use the Keyway broach to make the cut in both the shaft, and the hub. Then use a square Key instead of the woodruf key.
(stronger) JimN
