Woodruff key repair in P.S. shaft
Posted by SDE on August 31, 2009 at 03:28:47 from (174.124.10.117):
Has anyone used J.B. WELD or Locite to fill in around the key? Is it durable enough? I am going to switch the coupler, end for end, to get the end with good keyway over the woodruff key. The crossholes that the bolts go thru are not the same size. I am going to drill them out to 3/8 and hope that it will keep everything tight enough to keep the woodruff key from moveing around. Otherwise I will buy a .250 key and taper it down to .190 to fit the shaft.
Thank you
Steve
