Re: Farmall M wheelbase settings
Posted by RustyFarmall on August 31, 2009 at 08:23:31 from (209.152.78.140):
In Reply to: Farmall M wheelbase settings posted by J.D.HEICHEL on August 31, 2009 at 08:07:22:
Those 2 washers and chunks of metal could possibly be left over from a previous repair, but you'll never know until you dig deeper, and if it were mine, I would want to exactly where they came from. Stray parts floating around inside the clutch housing may be harmless enough, but could also indicate something that needs to be fixed.
Rear wheel width is determined by what the tractor will be used for. The absolute widest setting will result in a very stable and safe ride but can become quite awkward also.
If you will be hauling the tractor on a trailer, you want those rear wheels slid all the way in.
