Re: Woodruff key repair in P.S. shaft
Posted by SDE on August 31, 2009 at 16:03:45 from (174.124.10.117):
In Reply to: Woodruff key repair in P.S. shaft posted by SDE on August 31, 2009 at 03:28:47:
I am going to make a new coupling. The damaged shaft will need some repair. It has been suggested at work, that I could form a piece of copper tubing ,to fit into the woodruff key slot an weld the shaft. Has anyone else heard of something like this?
Thank you Steve
