Re: Woodruff key repair in P.S. shaft
Posted by mattofvinings on August 31, 2009 at 18:12:24 from (67.142.161.29):
In Reply to: Woodruff key repair in P.S. shaft posted by SDE on August 31, 2009 at 03:28:47:
The epoxy is not a reliable fix.
Stepped key is your best bet.
Make it tight, a light tap fit with a hammer and you'll have no more trouble.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
