Touch Control problem or Hydraulic pump problem?
Posted by SteveNH on September 01, 2009 at 05:52:33 from (149.32.192.33):
Hi.
I have a 1948 Super A and am having some hydraulic problems. One side of the hydraulics always seems to work like it should, the arms that do not attach to the rear rockshaft. The side that attaches to the rear rockshaft always seems to lose prime when the tractor sits and takes about 5 minutes of moving the touch control lever back and forth before the arm will move. I also notice that when that side is left in the up position and the tractor is turned off the hydraulics on that side will slowly drop to the ground while the touch control lever remains in the up position. Maybe a bad seal in the touch control unit and time for a rebuild? I am thinking the pump is OK since the other side seems to be fine.
Thanks.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
