Re: Touch Control problem or Hydraulic pump problem?
Posted by Dave From Texas on September 01, 2009 at 06:52:12 from (144.177.70.5):
In Reply to: Touch Control problem or Hydraulic pump problem? posted by SteveNH on September 01, 2009 at 05:52:33:
I am probably not much help because I can not solve my own Touch Control proble. Have you checked your inlet screen? That could slow things down. I think both sides have the same regulator valve but have different shuttle valves. Chech the O rings on the shuttle valve. That could explane the leaking down problem also. Sounds like the pump is OK. My problem is that the pump will not unload.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
