Posted by Andy Martin on September 01, 2009 at 14:03:43 from (199.197.2.145):
In Reply to: Super M head posted by Larry Hatfield on September 01, 2009 at 11:23:21:
How badly is it cracked? The heads are thick and small heat cracks are common. If it does not leak, and no cracks run through a valve seat area it may be perfectly good to use. Head shops used to know this but they have dealt with high compression engines for so long most will condemn perfectly good heads.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
