Super M head
Posted by Larry Hatfield on September 01, 2009 at 11:23:21 from (208.102.74.223):
I have a Farmall Super M which has crack head casting. The casting # on this head is 8060-DC. Wondering if head casting # 8574-DC is interchangeable with the 8060-DC and will work on the Super M? The engine is a C264. Thanks for any help with my problem. Larry
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
