Re: Timing without a timing mark
Posted by Andy Martin on September 01, 2009 at 14:10:47 from (199.197.2.145):
In Reply to: Timing without a timing mark posted by PurdueAg on September 01, 2009 at 09:57:39:
To add to what the others have said, if you have the head off you have the pan off. You can get pretty close to TDC by looking at the rod from below and turning the crank until it is vertical. Two pistons will be down and two will be up and the rods only line up at TDC for two and BDC for the other two. Since TDC and BDC crank throws are going in opposite directions you can tell when they get close to matching.
