Loctite Quick Metal 660. It is an anaerobic compound like the rest of the Loctite family and set in the absence of air. Sets in 10 min, full cure in 22-24 hours. GOOD STUFF. If you do not use a release agent, a little heat will let it be removed later.
Tomorrow I am going to use it on my JD 616 rotary mower. The blade holder hub had got loose before I got it and beat up the splines. JD only wants $578 + tax for the part. I paid $550 for the mower. The gearbox is ok. I had a 3" washer made, 1/2" thick out of 4140 tool steel. I am also going to drill and tap the hub to accept 3, 3/8"-24 bolts (in case the bolt comes loose again I'll keep the washer!). I plan to fill the splines with Loctite 660 then torque the bolt down with my little Ingersoll-Rand 2141 3/4" impact. Hopefully it will stay together this time.
Good luck with the steering coupler. Loctite 660 is not cheap, far from it. 6ml is about $12 and 50ml is about $40. It will fill up to about 0.020" diametral clearance. Typical applications include restoring correct fits on worn shafts, spun bearings, and damaged keyways.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
