826 stops then goes
Posted by Bradford on September 03, 2009 at 20:10:42 from (76.30.244.30):
I have a 826 runs great. Was bushhogging the other day and twice it stopped like I pushed the clutch in. I did press the clutch in then let it out and it was fine. I cut for 4-5 hours with no problem otherwise. The T/A is out it does nothing and it freewheels going down a hill. The only other difference is I was in low 4th and the shifter grabs fourth when the lever hits the housing, there is no space below the shifter. the steering works good enough but could probably be better. Should I leave the T/A forward or back if it doesn"t work or does it matter?
