Re: Farmall H miss and throttle issue
Posted by TomH in PA on September 06, 2009 at 05:43:13 from (67.234.49.206):
In Reply to: Farmall H miss and throttle issue posted by A Miller on September 06, 2009 at 05:25:50:
My H has started doing the same thing. I suspect it's a carburetor adjustment issue but I can't find the problem. I put in a new carb overhaul kit which helped but it still stop/starts like that.
Setting the timing is pretty easy, you loosen the distributor and turn it a little. It helps to have a timing light, but you can get close by lining up the timing arrow with the notch on the pulley (on the left side near the governor) then turning the distributor until the points just open.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
