Re: Started the 400 parts tractor today
Posted by sflem849 on September 06, 2009 at 20:24:20 from (66.254.196.101):
In Reply to: Started the 400 parts tractor today posted by SDE on September 06, 2009 at 13:42:03:
IMNHO 12 volts is over rated. A real mechanic will make it work on the stock system. It was good enough for the first fifty years :)
