Re: Which switch should I get?
Posted by John T on September 08, 2009 at 04:08:38 from (66.244.97.31):
In Reply to: Which switch should I get? posted by Mike CA on September 07, 2009 at 23:18:43:
Mike, you cant have it both ways, you gotta make a choice:
If you go with a Cutout Relay versus a Voltage Regulator YOU GOTTA HAVE THE 4 POSITION LHBD SWITCH becasue the gennys FLD post must wire up to that switch to regulate either Low or High charge rate.
If you want the 3 position (its a light switch ONLY) switch then you need to use a Voltage Regulator in which caze it has a FLD terminal for the gennys FLD post to connect to (NOT up to light switch).
Originality is fine if that your choice (relay and LHBD switch) while the Voltage Regulator actually does a better job of automatically controlling charge rate.
John T
