Friends 450 will not lift a disc.
Posted by Butch WI on September 09, 2009 at 15:47:21 from (174.42.163.142):
Hello all,
A friend of mine has a 450 that will not lift a disc using the hydraulic remotes. It moves the cylinder alone back and forth but it will not lift the weight of the disc. The oil level is fine. It is in the double action cylinder position. It moves the FH fine also. We have not tried to attach something with substantial weight to the FH either to test it although this past spring it was used for plowing. w/ a 3 bottom FH plow. Any suggestions. The hydraulics had not been used for anything other that the FH far a long time...Years.
Thanks
Butch
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
