Mackinac Bridge tractor tour
Posted by Pete in Holland, MI on September 11, 2009 at 07:41:54 from (198.36.95.12):
Hey all -
Am sure most Michiganders are aware, but guessing most of you outside of the state have not. On September, 19th, a registered lot of 839 antique tractors will be driving across the Mackinac Bridge in northern Michigan. This is a 5 mile long suspension bridge that crosses the straits between upper & lower Michigan. It is somewhere around 200' off the water in the center of the bridge. Overall, the route is 20 miles long and should be a grand time with tractors of all colors on the tour. This is the second year this is going on.
Will be taking my W-30 with me and will be shooting a lot of pictures.
Pete
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
