Re: Farmall M Pulley Removal
Posted by Too Far Gone on September 11, 2009 at 15:36:15 from (67.221.197.94):
In Reply to: Farmall M Pulley Removal posted by Melvin Ware on September 11, 2009 at 11:24:42:
There is threads on there,probably full of hard grease and red paint.If need be use a torch to burn that stuff off there .Soaking does a lot more good when the oil can get in there
