Re: Farmall M Pulley Removal
Posted by Melvin Ware on September 11, 2009 at 19:18:35 from (4.152.108.127):
In Reply to: Re: Farmall M Pulley Removal posted by old on September 11, 2009 at 13:33:09:
I'll try putting the screw hole on top as you suggested. Do you have a good method for getting the PB up and into the hole? Also, what did you use to strike the pulley and are the sides of the "hump" normally angled as they are on mine? I also plan to clean up the threads using a wire brush and perhaps a torch as others have suggested.
