Re: Farmall M Pulley Removal
Posted by old on September 11, 2009 at 13:33:09 from (4.244.186.18):
In Reply to: Farmall M Pulley Removal posted by Melvin Ware on September 11, 2009 at 11:24:42:
Get that set screw hole up to the top and then fill it with PB etc. Let it sit a day or so. Also I have found that if you tap on the edge of the pulley some that that seems to help pop them loose. Of course don't slam it real hard just some good light taps all the way around it. I have had the same problem in the past and also try it both ways tighten/loosen and some times working it back and forth will help also
