Posted by John A . on September 11, 2009 at 22:40:59 from (76.1.122.170):
In Reply to: Re: Farmall 450 LP ? posted by Owen Aaland on September 11, 2009 at 16:59:45:
Owen, By in large most tanks I have seen were clearly labeled with an aluminum ring tag on the valve handle or a welded on tag on the tank. If the stick on tag is gone the "vapor" will be the valve that primarly has only vapor come out when opened. The "Liquid" will have liquid LP come out when opened. If you can not tell then Your theory will do just fine! I have worn out 4 or 5 pickups on LP and run more LP tractors than I can count I have never seen a tank where the valves were strung out all over a tank! If so it was a nightmare to manufacture, Where the ones with the valves in one central location were easier to manufacture and quality control was held to a higher level. Tell me about the tank you have in question! Its make and application! Later, John A.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
