Re: Farmall 450 LP ?
Posted by Owen Aaland on September 11, 2009 at 16:59:45 from (207.13.114.55):
In Reply to: Re: Farmall 450 LP ? posted by John Athey on September 11, 2009 at 12:11:31:
John A. said: (quoted from post at 15:11:31 09/11/09) Owen, In theory you are correct. but not necesserly the case! It will be the valve that the entrance to it is at the highest point In the tank or any where above the liquid full line, that is the 80% full line. Look at your 450LP, both valves are at the same level on the tank, But the liquid valves draws off the bottom of the tank, and the vapor draws off the top. See what I mean? Hope this helps!
Later,
John A.
Which is why I qualifies my statement and did not address tanks that have both valves at the same level. I have seen tanks that have both valves near the top and others that have both valves near the bottom. Unfortunately too many are only marked with a stick on label that disappears after years of use, especially on trucks and RVs.
