Re: Thanks -- 350 Utility Temp Gauge Reading
Posted by Rumplestiltskin on September 12, 2009 at 11:21:17 from (166.164.229.16):
In Reply to: 350 Utility Temp Gauge Reading posted by mattofvinings on September 11, 2009 at 17:27:00:
mattofvinings said: (quoted from post at 17:27:00 09/11/09) The general strategy I've seen for coolant temp gages on a number of automotive engines is to (ideally)
- read liquid temp when bathed by liquid
- read metal temp when no liquid
However, a very common occurrence is that when the liquid subsides from being low or boiled off, the probe reads air temp...which is unsuitably low.
My thoughts are that the temp probe should be like a flat puck that fits tightly against a machined area on the cylinder head, intake manifold, etc so that the water jacket bathes the area in a strong flow of coolant when OK and then you actually do read the metal temp when the liquid disappears.
So far this brilliant idea isn't in production anywhere in the world so take my confidence in its superiority with a few blocks of salt.
I like that idea, Matt. you could place the sensor at (or very near to) the spot where you really want to know the temperature. You may even decide you don't care about the coolant temp as long as you know the metal temp; then the sensor wouldn't have to contact the fluid (one less hole needed in the cooling system).
Mark W. in MI
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
