Most older era tractors will crank with the ignition off. Normal. (the following assumes it is a 10SI Delco alternator) The Transpo 07 box is probably a conversion to (what someone thinks) is a one wire system. Scrap the box. Attach the #2 spade terminal on the alternator to the big terminal on the alternator (short 12ga wire). Attach that same big terminal to the load side of the amp meter with 10 gauge wire (It may be already). Attach the #1 spade terminal of the alternator to the banded end of a 3 amp 100piv diode (radio shack)attach the other end of the diode to the ignition switch terminal that goes to the coil. That is it, it will work. If it has a magneto, (or if you want to) you can put a momentary contact single pole Switch in place of the diode. Then when it starts you can push the button to energize the alternator, and release it. It will continue to charge from then on. An oil pressure switch can be used (closed on pressure -NAPA item) to do the same thing automatically. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
