Re: Super A 12 volt alternator and wiring
Posted by aquanosis on September 12, 2009 at 14:46:45 from (67.241.20.22):
In Reply to: Super A 12 volt alternator and wiring posted by Janicholson on September 12, 2009 at 14:15:24:
Thanks for the info. When I attach the diode to the ignition switch and the #1 terminal on the alternator, what size wire should I use to connect the gap? does it matter where the diode is in the line (at the switch end or alternator end...somewhere in between). Can I use the wire (already there) that was to be used on the voltage regulator of the original 6 volt? Thanks
