I may be wrong but I got the impression from your last post that you may think the throw-out bearing is the same as the pilot bearing.
The pilot bearing will be a ball bearing pressed into the end of the crankshaft but more likely into the flywheel. They can seize up and eventually grab the splined clutch shaft through a galling action. I had a Cub do that to me many years ago. The main difference with the Cub is that the pilot bearing was a bronze bushing. Your bearing should have made some noise when disengaging the clutch before it seized on the shaft. This is not a diagnosis of what is actually wrong with your 504.
A throwout bearing may have some wobble. The bearing will still be good. It is just the bearing carrier/yoke that is allowed to find its center when pressed against the pressure plate fingers. In other words, it floats a little.
I don't fully understand TA's as well even though I have replaced one and, at the same time, changed the output bearing, flange, shaft to the larger size. I just set them according to the manual.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
